PreviousNext
JavaScript must be enabled to correctly display this content
Redeeming Gift Cards
Begin a check.
Navigate to the gift and loyalty screen, and then select
the function key to redeem a gift card.
Swipe the card or enter the card number.
If a guest’s card has been linked to multiple Stored Value
and Gift card programs, select the program to redeem.
Enter the amount to redeem from the card.
If the amount is less than or equal to the gift card balance,
the card balance is applied to the check and deducted from the card.
If the amount exceeds the gift card balance, the full card
balance is applied to the check and the card balance becomes 0.00.
Apply another tender (cash, credit card, or another gift card) to
pay the remaining check balance.
If the check amount is zero, enter a value of zero when redeeming
the card.
Some gift card drivers (using the Command Module /
XProcessor) use a separate Gift Card Redemption function button. For
Simphony Payment Interface (SPI) users, gift cards are redeemed by
using the SPI payment function buttons (CC Auth, CC Final, or Authorization
& Pay).
