Oracle Argus Safety UI Entry
The PMDA (R3) Paper forms are configured under the new flexible code list LM_REPORT_FORMS_EXPEDITED. The path of reports can be configured in these code lists as shown below.
The columns present in this code list are used as shown here:
| Column | Description |
CODE |
This is auto generated. |
RPT_TYPE |
0 = Expedited, 1 = Periodic. |
FORM_CATEGORY |
This column is used to identify the category of report forms e.g. for all PMDA forms, it is 1; otherwise 0. |
REPPATH |
The report path of the Oracle Business Intelligence Publisher. |
BIPREPTYP |
Report template value to be matched with CFG_RPT_AGG_PARAMS. Default value is 11. |
The remaining columns are currently not used.
Parent topic: PMDA (R3) Paper Report templates
