Configuring LAM System Numbering
This section enables you to specify the case numbering preferences for LAM cases. The system provides the ability to use multiple case numbering schemes for global use. For example, if site is used in the numbering, the system provides the option to keep separate sequences for each site.
Select System Configuration > LAM System Numbering to view
the LAM System Numbering screen shown in the following illustration.
For more information, see:
Parent topic: System Configuration
