User's Guide Process case data Review cases Generate a letter on a case Generate a letter on a case Hover over the Case Actions menu, and click Open. On the Case Selection page, enter the search criteria for a case and click Search. From the results list, select a case. From the Case Form for the case, click the Activities tab. In the Contact Log section, click New Letter. From the Custom Letter Templates dialog box, select a letter template and click OK. From the Save Letter dialog box, click Yes and modify the application generated letter as appropriate. Alternately, click No to save the Oracle Argus generated letter as is. In the Attach Letter for Case dialog box, click Browse and navigate to the location of the saved letter. Tip: You can then modify the value in the Date Sent field in the Contact Log to schedule an action item for the letter. Parent topic: Review cases
