Track bulk incoming ICSR reports
The Bulk Incoming ICR Reports enable you to import multiple ICSR reports that are sent by the agency or trading partner. To view the Bulk Incoming Reports:
- Select multiple reports from the Incoming ICSR Reports screen.
- Click Accept ICSRs.
Note that:
- The reports that are imported can be a combination of Initial, Follow-up, and Nullification reports.
- The only pre-requisite for this dialog box is that Case numbering should be set to auto-numbering and not manually.
- Bulk Incoming Reports does not prevent the duplicate cases to be loaded into the system.
The following table lists Bulk Incoming Reports fields.
| Field | Description |
Agency Name |
This drop-down list contains unique trading partner from the ICSR reports have been received. Select an agency/trading partner to filter the ICSR reports. |
Product Name |
This drop-down list contains unique suspect Product Names extracted from the received ICSR reports. Select a suspect product to filter the ICSR reports. If an Agency Name is selected, the Product Name list contains all suspect products belonging to that agency name. |
Follow Up Output Format |
This drop-down list contains CIOMS-I, MedWatch, and Case Form. You can print all ICSR reports only if the Follow Up checkbox is checked. |
Source Count |
Displays the total number of ICSR reports with breakdown in Initial, Follow Up, and Nullification category. |
Selected Count |
Displays the number of ICSR selected by the user to load the ICSR reports in Argus Safety. Selected count can be changed by checking the Initial, Follow Up, or Nullification checkbox. |
Import |
Imports all the reports. Note: For the Import process, if the system receives an ICSR report with the Medically Confirm field set to 1, the Primary reporter is marked as HCP. |
Cancel |
Removes the Import ICSR reports window. |
Parent topic: Manage your Incoming ICSRs
