Output Formats
Out-of-the-box Argus Safety BI Publisher reports support the following output formats by default:
- RTF
You can also get the output in an XML format. The out-of-the-box reports are not designed to support the CSV format. However, you can prepare a custom report supporting the CSV format.
Parent topic: Overview
