Oracle 19.14 for Windows 64-bit
Oracle Database Client patches for Windows 64-bit
Oracle version |
Patch number |
Patch application order |
Notes |
19.3 |
N/A |
1 |
Patch set/Base install Oracle 19.3.0.0 |
19.14 |
33575656 |
2 |
Windows DB Bundle Patch 19.14.0.0.220118. |
19.14 |
33641592 |
3 |
Interim patch. Prevents the "UNICODE STRING STORED INCORRECTLY IN CLOB IN 64 BIT 19.13 CLIENT" from occurring when starting the study. Request this patch at support.oracle.com |
Note: Oracle Database Client 19.14 requires the interim patch to be applied prior to running studies in InForm. Studies that are set up or started without the interim patch will fail, and will not be recoverable even if the patch is applied later.
