Multilingual data
The Central Coding application can accept both English and Japanese verbatims (multilingual data).
- When you install the Central Coding application on an English operating system, you can choose whether to use multilingual data.
- When you install the Central Coding application on a Japanese operating system, the installation program assumes that there will be multilingual data.
If you choose to use multilingual data, the Central Coding installation program:
- Loads the Japanese report templates. These reports contain the MS Mincho or MS UI Gothic font so that Japanese text appears correctly in the reports. These reports can contain both Japanese and English data.
- Sets the default date format to YYYY/MON/DD HH24:MI:SS. In an environment with native authentication, you can modify this setting as needed on the System Configuration page.
Note: You cannot perform an upgrade to support the Japanese language.
