About integrating with the Clintrial or InForm application
The Central Coding application supports integration with the InForm application and the Clintrial application at the same time under the following circumstances:
- One of the following is true:
- The InForm application, Clintrial application, and Central Coding application are behind the same firewall.
- The InForm application, Clintrial application, and Central Coding application are not behind the same firewall, but a VPN is used between the Central Coding application and the Clintrial application.
- The Clintrial software is installed on a different machine than any of the Central Coding application servers.
- The InForm software and the InForm Adapter software are installed on a different machine than any of the Central Coding application servers.
To determine the hardware and software requirements for using the Central Coding application with another application through the Services Interface (API), consult your Oracle Services representative.
