Verify the installation
After the application server is created, do the following to verify that the installation was successful:
- Review the setup log.
This log contains messages the system generated during the installation. It is available in <Installation Folder>\CentralCodingServer\Setuplog.txt.
If the following message appears in Setuplog.txt it indicates that the block size of the tablespace for the Central Coding user is not large enough. For more information, see Mandatory database parameters.
create index CCA_FLAT_LEVELS_IDX1 on CCA_FLAT_LEVELS (*
ERROR at line 1:
ORA-01450: maximum key length (6398) exceeded
- In IIS, verify that centralcoding<InstanceName> exists; <InstanceName> is the Instance Name you entered on the Application Instance Settings page during the Central Coding installation.
- To open IIS, select Start > Apps > Internet Information Services (IIS) Manager.
- Double-click the machine name, expand Sites > Default Web Sites, and locate centralcoding<InstanceName>.
- Verify that the Dictionary Loader tool is installed.
If you selected Dictionary Loader on the Select Features page when you installed the Central Coding software, the Dictionary Loader tool is available from the Start menu under Oracle HS.
Note: For instructions on using the Dictionary Loader tool to load and manage the coding dictionaries, see Loading and managing the coding dictionaries.
