Launching the Dictionary Loader tool
Use the Dictionary Loader tool for all dictionary installation and maintenance tasks.
- Select Start > Apps > Dictionary Loader.
The Dictionary Loader dialog box appears.
Note: When you upgrade the Central Coding software, information about previously defined connections appears in the Data Connections tree. The upgrade may delete the connections that were defined for the dictionary repository. You can restore the connections using the previous user information so that the dictionary repository objects become available again. For more information, see Creating a connection to the database.
