Dictionary statuses
Descriptions of dictionary statuses
Status |
Description |
DEFINED |
The type, version, culture, and schema that hold data for the dictionary are defined. Data is not loaded into the schema. |
LOADED |
Data is loaded into the schema for the defined dictionary. |
ACTIVE |
The dictionary is defined, data is loaded into the schema, and the dictionary is available for coding. |
INACTIVE |
The dictionary is defined and data is loaded into the schema, but the dictionary is not available for coding. |
REMOVED |
The schema and data associated with the dictionary are deleted. |
