Overview of the steps to load a standard coding dictionary
Steps to load a standard coding dictionary
Step |
Task |
Description |
1 |
If you are using a WHO-DD dictionary, determine whether you are using a pre-ICH or ICH format of the dictionary. |
For more information, see: |
2 |
Make sure that the dictionary type for the dictionary that you want to load has been imported. |
For more information, see Importing the dictionary type XML file. |
3 |
Make sure that the dictionary connection is established. |
For more information, see Viewing the dictionaries available for a database connection. |
4 |
The Dictionary Loader tool uses dictionary types to create dictionary schemas. |
5 |
Load dictionary data into the database using the schema that you generated. The dictionary schema must exist before you can load data into it. |
6 |
Dictionaries must be activated to be used for coding. |
