Event Log Messages workspace
If your environment supports a web farm, you work with entries from the Event Log in the Event Log Messages workspace.
Each application server in the web farm contains a separate Event Log. However, all information, warning, and error messages that are related to the Central Designer application are collected in a table in the database. The table contains one row for each entry in the Event Log.
You can request the messages for a range of dates. An XML file that contains log information is created. You can analyze the XML file using an application that views XML information, or you can use an XSLT transfer to read the file in the Microsoft Internet Explorer browser.
The limit for the number of entries in the log is 10,000 by default, but you can configure the number. An Oracle database job runs nightly to delete older records that exceed the limit for the number of entries. The next Oracle database job that runs uses the setting that you provide. Additionally, at any time you can delete all entries in the log or entries that were logged before a specified date.
