Dictionary Types workspace
In the Dictionary Types workspace, you import and enable dictionary types. You also can overwrite dictionary types. A dictionary type is a name or identifier for the metadata for a dictionary.
Description of dictionary types
Characteristic |
Description |
Definition and purpose |
A dictionary type is a name or identifier for the metadata for a dictionary. You create a coding map for a verbatim using a dictionary type. The dictionary type specifies the metadata for all versions of a dictionary, including:
Dictionary types in the installation |
The following dictionary types are installed with the Central Designer application:
Importing |
You can import other standard dictionary types as well as custom dictionary types in the Central Designer Administrator application. For more information, see Importing and overwriting a dictionary type. |
Multiple versions |
The Central Designer application supports multiple versions of a dictionary type. A version consists of dictionary metadata and dictionary data. In most cases, versions are different only in data, but new versions can also contain new metadata. |
Using in a study or library |
To use a coding dictionary in a study or library to create coding maps, you must use the following process:
Association with verbatim types |
You can associate multiple verbatim types with a single dictionary type. |
Deployment |
Dictionary types that are used in the coding maps are deployed to the InForm application as MedML DICTIONARY objects. |
To open the Dictionary Types workspace:
- Click the System Config button.
- Under Coding, click Dictionary Types.
Dictionary Types workspace - Field descriptions
Field |
Description |
Type |
Name of the dictionary type. Note: In the dictionary type XML file, this information comes from the DictionaryType type field. You can modify this information by double-clicking the Type field. |
Description |
Description of the dictionary type. Note: In the dictionary type XML file, this information comes from the Description field. You can modify this information by double-clicking the Description field. |
Import date |
Date on which the dictionary type was imported. |
Enabled |
Indicates whether the dictionary type is enabled. Only enabled dictionary types can be used to create coding definitions in the Central Designer application. |
