Updating report definitions
On each Central Designer application server:
- Copy the updated custom reports definition file to the following location, overwriting the existing file:
<designer_root>\ DBSchema\_Last\Datainstaller\DesignerReportsDefinitions.xml
In the previous location, <designer_root> is the root directory of the Central Designer installation.
- From the <designer_root>\bin directory, run the UpdateReports.bat file.
The UpdateReports.bat file updates the definitions of the custom reports in the database.
