Importing, exporting, and deleting system settings
To import system settings from a file:
- Select System Configuration.
- Under General, select System Settings.
The System Settings workspace appears.
- Click Import.
The Open dialog box appears.
- Navigate to the location of the XML file that contains the system settings, and select it.
- Click Open.
Note: If system settings already exist for an InForm release, you must delete the settings before you can import other settings for the same release.
To export system settings to a file:
- From the Settings drop-down list, select the InForm release to export.
- Click Export.
The Export dialog box appears.
- Navigate to the location in which to save the fie, and do the following:
- Type a name for the file.
- From the Save as type drop-down list, select XML.
- Click Save.
To delete system settings:
- From the Settings drop-down list, select an InForm release.
- Click Delete.
A confirmation dialog box appears.
- Click OK.
