Adding, modifying, and deleting a task type
If tasks that are based on a task type exist, you cannot delete the task type.
- Select System Config.
- In the Collaboration section, click the Task Types link.
The Task Types workspace appears. It contains information about existing task types, followed by a blank row.
- Fill in the fields in the blank row, and click Save.
- Select the type that you want to modify.
- For the selected type, click a field, and modify the information as necessary.
- Click Save.
- Right-click the type you want to delete, and select Delete Row.
Task Types workspace - Field descriptions.
Field descriptions for the Task Types workspace
Field |
Description |
Name |
Name of the task type. |
Description |
Description of the task type. |
Task Classification |
Classification of the task.
Assigned To |
Study or library team to which tasks of this type are assigned by default. Notes:
