Removing a user from a role
- Click the Roles button.
- In the Roles list, select the role from which you want to remove a user.
The Roles workspace appears.
- Select the Users tab.
- In the Selected Users action list, select the user that you want to remove from the role and click the left arrow button.
Note: To select more than one user, use Ctrl+click or Shift+click.
The user is moved to the Available Users action list.
- Click Save.
