Categorization tab
In the Categorization tab of the Users workspace, you associate a user with keywords and categories.
A keyword is an identifier that is associated with users and study objects to facilitate more powerful and efficient searches. A keyword can be system-generated or user-defined.
- System keywords are keywords that are installed by default with the Central Designer application or that an administrator creates in the Central Designer Administrator application.
- User keywords are keywords that a Central Designer user creates.
A category is a hierarchical grouping of keywords. You can create categories only from existing keywords. A category can be automatically generated or manually generated.
- Automatically generated categories are categories that automatically catalog study objects by auditing information (for example, the study object type, original author, creation date, and library in which the study object was created).
- Manually generated categories are categories that you create by dragging keywords to the Categories tree.
