Saving and resetting in the Central Designer Administrator application
Some workspaces contain two buttons at the bottom-right corner:
- Reset—Clears unsaved data that has been entered in the workspace.
- Save—Saves the changes that you made in the workspace or tab.
Note: If you have made changes and select another button or tab, you are prompted to save changes, discard changes, or cancel.
