Roles workspace—Right descriptions
When you create a role, you choose the scope of the role. A role can have a library, study, or application scope. Each scope has a set of rights that you can grant to the role.
- Roles with the library scope become library teams in the Central Designer application.
- Roles with the study scope become study teams in the Central Designer application.
Users are granted rights associated with roles in the following manner:
- Application roles
A user assigned to an application role is granted all of the rights that are associated with the role, without restrictions. For example, a user who has the right to create users can always create users.
For more information, see Application roles—Right descriptions.
- Library roles
A user assigned to a library role is granted the rights associated with the role only in libraries where that user is also a member of the library team. For example, if a user is assigned to the Librarian library role in the Central Designer Administrator application, the user must be a member of the Librarian library team for a library (in the Central Designer application) to work in the library.
For more information, see Library roles—Right descriptions.
- Study roles
A user assigned to a study role is granted the rights associated with the role only in studies where the user is also a member of the study team. For example, if a user is assigned to the Rule Creation study role in the Central Designer Administrator application, the user must also be a member of the Rule Creation study team for a study to create rules in the study.
For more information, see Study roles—Right descriptions.
Note: You assign users to roles in the Central Designer Administrator application and to study and library teams in the Central Designer application.
