Adding, modifying, and deleting a verbatim type
- Select System Config.
- In the Coding section, click the Verbatim Types link.
The Verbatim Types workspace appears. It displays information about existing verbatim types, followed by a blank row.
- Do one of the following:
- To add a verbatim type: Type the name and description in the blank row.
- To modify a verbatim type: Double-click the text that you want to modify, and type the correct text. Click Save.
- To delete a verbatim type: Right-click the verbatim type, and select Delete Row.
Note: You cannot delete a verbatim type that is in use.
