Information that is stored in the database
Units information and report definitions are stored in the database and are used by all application servers in a web farm.
- You can export the units information to a file and then modify and import the file. You perform this task in the Central Designer Administrator application.
- If you have created custom reports, you must back up the Report configuration section of the DesignerWebServices.config file before upgrading and then import it into the database.
For more information about working with this information, see the Administrator Guide.
