Logging on to the Central Designer Administrator application
An administrator must log on to the Central Designer Administrator application and create user accounts before other users can log on and use the Central Designer application.
- Using Internet Explorer, navigate to the following address:
http://<server name>/CentralDesignerInstall
In the previous address, <server name> is the name of the application server computer.
- Click the Start Central Designer Administrator link.
A dialog box appears, indicating that the application is starting.
The logon window appears.
- Enter the following information:
- User name—system.
- Password—Password you set during the server installation.
- If the web browser connects to the network through a proxy server that requires authentication, click Proxy Settings to enter the user name, the password, and the domain used to authenticate the connection to the proxy server.
- Click Log On.
The application opens.
Oracle recommends:
- Changing the password of the system account after you log on to the Central Designer Administrator application.
For more information, see Changing your password in the Central Designer Administrator application.
- Deactivating or terminating the system user after you create and activate users.
For more information, see the Administrator Guide.
