Creating a sample deployment package using the sample study
The Central Designer installation package contains a sample study and units file. You can import the files into the Central Designer application and then deploy the sample study to the InForm application using a manual deployment. Perform the following steps to create a sample deployment package.
Step |
Task |
More information |
1 |
Import the DesignerUnit.xml file into the Central Designer Administrator application. This file updates custom units of measurement. |
Exporting and importing a units file in the Administrator Guide. The DesignerUnit.xml file is located in the Central Designer installation package in the InstallSupport\Sample Trial folder. |
2 |
Set up locales in the Central Designer Administrator application, and include the following locales for the sample study:
Adding and removing a locale in the Administrator Guide. |
3 |
Import the CSML for the sample study into a new study project. |
Importing study objects in the User Guide. The CSML for the sample study is located in the Central Designer installation package in the InstallSupport\Sample Trial folder. |
4 |
Add the locales from step 2 to the study. |
Selecting the supported locales for a study in the User Guide. |
5 |
Select all the dictionary types and all their verbatim types on the Coding tab. |
Select dictionary types and verbatim types for a study in the User Guide. |
6 |
Validate the study to create a baseline, and choose to ignore the warnings. |
Validate a study and create a baseline in the User Guide. |
7 |
Create a deployment package.
Create a deployment package from a validation baseline in the User Guide. |
8 |
Save the deployment package to the local computer. |
Saving a deployment package in the User Guide. |
9 |
Copy the deployment package and the public key to a location that is accessible to the InForm server. |
No additional information. |
10 |
Perform additional steps in the InForm application to finish setting up the study.
InForm Installation Guide. |
