Rule Templates tab—Option descriptions
The grid displays rule templates created on the study object selected in the Project Explorer.
Option |
Description |
Rule templates grid |
Data Type |
Return type of the rule template. |
Description |
Description of the rule template. |
Display Text |
Text that appears in the Rule Summary section of the Rule wizard after the When Value Is information. |
Id |
Identification information for the rule. |
Expression |
Rule expression of the rule template. |
Parameters |
Specified parameters of the rule template, separated by semicolons. |
Template Name |
Name of the rule template. |
Type |
Indicates that the rule was created using the Central Designer rule expression language. |
