_Count(String, Array, Boolean)
Counts the number of occurrences of a string value in an array.
Syntax
_Count(valueToCount,valueList,caseSensitive)
Parameters
Parameters for _Count(String, Array, Boolean)
Parameter |
Definition |
Data type |
valueToCount |
Value to count |
String |
valueList |
Array of values to search |
Array of String values |
caseSensitive |
Case sensitive search flag, True or False. If the value is True, the function takes case into consideration when searching for strings that match the value to count. For example, if caseSensitive is True, ABC is not counted as an occurrence of the string abc. |
Boolean |
Returns
The number of occurrences of a string value in an array.
