_IsValueGreaterThanArray (Float, Array)
Checks if a float value is greater than all of the date times in an array.
Syntax
_IsValueGreaterThanArray(valueToTest,valueList)
Parameters
Parameters for IsValueGreaterThanArray (Float, Array)
Parameter |
Definition |
Data type |
valueToTest |
Float value with which to compare the values in the array. |
Float |
valueList |
Array of float values against which to compare the value specified in the valueToTest parameter. |
Array of Float values |
Returns
True or False (Boolean), indicating whether the float value to test is greater than all of the elements in the array.
Notes
The valueToTest value is compared to each element of the array. If the value is greater than every element of the array, the method returns True. If at least one element is less than or equal to the value, the method returns False.
