_IsValueInArray (Float, Array)
Checks if a specified float value is equal to one of the float values in an array.
Syntax
_IsValueInArray(valueToTest,valueList)
Parameters
Parameters for _IsValueInArray (Float, Array)
Parameter |
Definition |
Data type |
valueToTest |
Float value with which to compare the values in the array. |
Float |
valueList |
Array of float values against which to compare the value specified in the valueToTest parameter. |
Array of Float values |
Returns
True or False (Boolean), indicating whether the float value to test is in the array of float values.
Notes
The valueToTest value is compared to each element of the array. If the value is equal to at least one element of the array, the method returns True. Otherwise, the method returns False.
