_IsValueInArray (Text, Array)
Checks if a specified text value is equal to one of the text values in an array.
Syntax
_IsValueInArray(valueToTest,valueList)
Parameters
Parameters for _IsValueInArray (Text, Array)
Parameter |
Definition |
Data type |
valueToTest |
Text value with which to compare the values in the array. |
Text |
valueList |
Array of text values against which to compare the value specified in the valueToTest parameter. |
Array of Text values |
Returns
True or False (Boolean), indicating whether the text value to test is in the array of text values.
Notes
The valueToTest value is compared to each element of the array. If the value is equal to at least one element of the array, the method returns True. Otherwise, the method returns False.
