_IsValueLessThanArray (Float, Array)
Checks if a specified float value is less than all float values in an array.
Syntax
_IsValueLessThanArray(valueToTest,valueList)
Parameters
Parameters for IsValueLessThanArray (Float, Array)
Parameter |
Definition |
Data type |
valueToTest |
Float value with which to compare the values in the array. |
Float |
valueList |
Array of float values against which to compare the value specified in the valueToTest parameter. |
Array of Float values |
Returns
True or False (Boolean), indicating whether the specified float value is less than all float values in an array.
Notes
The valueToTest value is compared to each element of the array. If the value is less than every element of the array, the method returns True. If at least one element is greater than or equal to the value, the method returns False.
