_IsValueLessThanOrEqualToArray (Integer, Array)
Checks if a specified integer value is less than or equal to at least one of the integer values in an array.
Syntax
_IsValueLessThanOrEqualToArray(valueToTest,valueList)
Parameters
Parameters for _IsValueLessThanOrEqualToArray
Parameter |
Definition |
Data type |
valueToTest |
Integer value with which to compare the values in the array. |
Integer |
valueList |
Array of integer values against which to compare the value specified in the valueToTest parameter. |
Array of Integer values |
Returns
True or False (Boolean), indicating whether the specified integer value is less than or equal to at least one of the integer values in an array.
Notes
The valueToTest value is compared to each element of the array. If the value is less than or equal to every element of the array, the method returns True. If at least one element is greater than the value, the method returns False.
