_CheckTextLength
Description of _CheckTextLength rule template
Characteristic |
Description |
Availability |
Text items |
Description |
Checks whether the value entered in the item is less than the maximum length. The maximum length is 255 by default, but you can specify any value when you create a rule based on the template. |
Returns |
Display text |
this.Value.Length < MaxLength |
