HasReviewStates
HasReviewState
Characteristic |
Description |
Icon |
Availability |
All non-deleted forms. |
Return type and description |
Boolean. Returns true if the form is in the review stage specified in the parameter. Review stages appear in the folder for the form. |
Syntax |
HasReviewState(Name of review stage) |
Parameters |
Example |
The following example returns True if the form is in the NeedsReview stage of the QA Review review state: HasReviewState(this.QAReview.NeedsReview) |
Purpose |
Use this method to check whether a form is in a particular review stage. |
