Including a function in a rule expression
Use either or both of the following methods:
- Select the function using the dynamic prompts that appear in the Expression workspace as you type.
For more information, see Using dynamic prompts in the Expression workplace.
- Drag the function from the Functions tab to the Expression workspace.
If parameters are associated with the function, the Invoke Function dialog box appears.
Note: The expression contains the name of the function, followed by parameters, which are enclosed by parentheses. Optionally, you can type the name of the function and its parameters.
