Constants tab—Option descriptions
Option descriptions for Constants tab
Option |
Description |
Fields |
Note: Not all fields appear in the default view. Optionally, you can add the other fields to the browser view, and you can rearrange the order of fields. For more information, see Showing and hiding a field in the User Guide. |
Classification |
User-defined text used to group, sort, and filter constants. |
Data Type |
Return type of the constant:
Description |
Description of the constant. |
Name |
Name of the constant. The name must:
Published (only in libraries) |
Indicates that the study object has been published. |
Value |
Value of the constant. |
Toolbar buttons |
New Constant Delete |
Create and delete a constant. |
Publish (only in libraries) |
Publish the selected constant. This button is enabled for library objects that have been saved. |
