RelatedData[]
RelatedData[]
Characteristic |
Description |
Icon |
Availability |
Repeating, associated form. |
Return type |
Description |
Returns instances of associated forms, sorted by form index, and allows access to arrays of item values from the associated forms. |
Example |
If the AE and CM forms are associated, and you are creating a rule on a study event that contains both of them:
Notes |
Trigger dependencies are created in the InForm application for a data-entry rule using associated forms. When the expression of a data-entry rule references the RelatedData rule model property, a trigger dependency is created for both the item that is explicitly referenced and the item that is referenced through the RelatedData property.
