Methods
A method is a block of code that is called by a rule and that is used to manipulate data.
You can use standard C# methods, including math methods, as well as methods that are automatically generated for certain study objects, to create rule expressions. For example, you can use a count method to return the number of instances created for a repeating form.
You can use any method in a rule expression.
