Frequently used operators
For more information, see a C# or Java programming reference.
Operator category |
Operator |
Use |
Description |
Arithmetic |
x + y |
Adds x and y. |
x - y |
Subtracts y from x. |
x * y |
Multiplies x by y. |
x / y |
Divides x by y. |
x % y |
Returns the remainder of integer division of x and y. |
Logical (Boolean and bitwise) |
x & y |
Evaluates both x and y and returns the logical conjunction ("AND") of their results. If x and y are integers, the logical conjunction is performed bitwise. |
x | y |
Evaluates x and y and returns the logical disjunction ("OR") of their results. If x and y are integers, the logical disjunction is performed bitwise. |
x ^ y |
Returns the exclusive or ("XOR") of their results. If x and y are integers, the exclusive or is performed bitwise. |
!x |
Evaluates x and returns the negation ("NOT") of the result.
~x |
Evaluates x and returns the bitwise negation of the result. ~x returns a value where each bit is the negation of the corresponding bit in the result of evaluating x. |
x && y |
Evaluates x.
Note that if evaluating y would hypothetically have no side effects, the results are identical to the logical conjunction performed by the & operator. |
x || y |
Evaluates x.
Note that if evaluating y would hypothetically have no side effects, the results are identical to the logical disjunction performed by the | operator. |
Used to group information. |
String concatenation |
x + y |
Concatenates strings. |
Relational |
x == y |
x != y |
Returns the logical negation of the operator ==.
x < y |
x > y |
x <= y |
x >= y |
Member access |
this.Value |
Used to form long names. |
Indexing |
Used to access array elements. |
Conditional |
x ? y : z |
Assignment |
x = y |
Assigns the value of y to x. |
