[Alias or code of codelist item]
Characteristic |
Description |
Icon |
Availability |
Items with a codelist. |
Return type |
One of the following:
Description |
Codelist item in the codelist that is associated with the item. When you use a codelist item in a rule expression, the value of the codelist item is used. |
Purpose |
The alias of a codelist item is useful because you can use the alias in place of the code in the codelist. The Rule Wizard allows you to drag the codelist item as a replacement for the code, so you do not have to memorize it or close the Rule Wizard to determine the value. |
