Form(Forms,Integer)
Form(Forms,Integer)
Characteristic |
Description |
Icon |
Availability |
When the Form and Form Index standard data dimensions are selected for the data set. Note: The Form Index standard data dimension is necessary for data sets that contain repeating study events. |
Returns |
A data set subset with data from only the form. |
Syntax |
NameOfDataSet.Form(Forms.form, formIndex) |
Parameters |
Parameter |
Definition |
Data type |
form |
Form on which to filter. |
Integer |
formIndex |
Index of the repeating form, from 0 to a maximum value, which equals the count of the repeating form instances. |
Integer |
