System requirements: Client computers
Feature |
Client requirement |
Operating system |
One of the following:
Processor |
Dual CPU Core i3, 2 GHz or higher |
Display |
Note: To avoid display issues in Central Designer, Oracle recommends that you do not set the Windows display size setting to Medium - 125%. |
Memory |
Minimum: 4 GB Recommended: 8 GB Note: If the computer has 512 MB or less, you cannot install the client applications. |
Disk space |
In addition to the space required for the operating system:
Software |
Bandwidth between the application server and client computers |
Minimum: 1.5 Mbps (T1) Recommended: 5 Mbps |
