Previous Topic
Next Topic
Book Contents
Create a deployment package: the basics
  1. At the bottom of the Project Explorer, click the Study Information (Study Information) button.
  2. Right-click a study, and select Create Deployment Package.
  3. To start the Create Deployment Package Wizard, click Next.
  4. On the Select a Deployment Package Type page, specify the type of deployment package to create (full, incremental, administration data, or custom events).
    Based on this choice, the Create Deployment Package Wizard prompts for different information as you progress through the wizard.
  5. On the final page of the Create Deployment Package Wizard, click Finish.
    A deployment package job starts, and a slide-up message appears to indicate when the job starts and completes.
  6. When the job completes, check the status in the Jobs Browser.
Tip Tip: Develop naming conventions for validation baselines and deployment packages. For example, name validation baselines that are created while testing the study design differently from validation baselines that are actually deployed.
Send Feedback
