Create and translate instructions and Help for a study design
You can create study documents that are specific to a target application or locale for study designs, study elements, study events, forms, sections, and items.
You can provide instructions and Help information if the study or library supports one or more locales, and if you have been given skills to work in the locales (in the Central Designer Administrator application).
To create and delete instructions and Help:
- In the Project Explorer, select a study object (study design, study element, study event, form, section, item, codelist, or codelist item).
- Select the Instructions & Help tab.
- To select a locale for the study documents, select the tab for the locale. The tabs are located along the bottom of the workspace.
- To create or edit study documents:
- Type in the text area.
- Optionally, use the toolbar to format the appearance of the text. You can use HTML formatting characters.
- To delete study documents:
- At the top of the Instructions & Help tab, click the Delete button.
- Choose one of the following options:
- Delete the study documents for only the selected locale.
- Delete the study documents for all locales.
To translate instructions and Help:
- Optionally, copy and paste study documents from a locale for which the information is already written.
- Select the locale to which you want to translate.
- Translate the study documents.
- Optionally, use the functions at the top of the Instructions & Help tab to format the appearance of the text.
