Translate the question text of an item
- At the bottom of the Project Explorer, click the Items (
) button, and expand the InForm Items folder. - Select an item.
- On the Design tab, in the Language column of the Languages section, click the arrow that appears when you move the cursor over the far-right side of the cell in the first available row, and select the language into which you want to translate the question text.
- In the Question column, type the translated text for the item question.
- In the Short Question column, type the translated text for the short version of the item question.
- Press Enter, or click the next row.
