Import study administration data
Pre-requisite: Create a study.
- At the bottom of the Project Explorer, click the Study Information (
) button. - In the Project Explorer, right-click the study, then click Import Study.
- When the Import Study wizard appears, click Next.
- Select whether to import CSML or ODM file or Harvest InForm Resources.
Your selection determines the options you can specify. For example, If you select CSML import type, you can specify whether to import study objects and administration data, administration data only, or study objects only.
- Click Next to progress through the wizard, and Finish to import the study objects and data.
For more information, see Import Wizard options - CSML or ODM file.
Pages in the import wizard for CSML or ODM files
Page
Option
Description
Welcome
Introduction page.
Import Type
Select the source of the data to import.
Import CSML or ODM file
Generate study objects from a file in CSML or ODM format.
Generate study objects from the components of an InForm study.
File Location
Path of file to import
Specify the path of the CSML or ODM import file, or click Browse to locate the import file.
Study Administration Import Mode
This page appears only for the CSML import type, if the CSML file contains study administration objects.
Import study objects and administration data.
Import both study objects and study administration objects.
Import administration data only.
Import only study administration objects.
Import study objects only.
Import only study objects.
Rule Import Mode
Rule Import Mode
Only the Import as Collaboration Notes option is supported. With this option, each imported rule is converted to a collaboration note in the Central Designer application.
Note: This option applies only if the Import Type is ODM; if the Import Type is CSML, the import process creates a Central Designer rule for each imported rule.
IPR Import Mode
Import IPR data
Select whether to import in-place revision objects.
Note: This page appears only if the file contains in-place revision objects.
Ready to Import Data to Central Designer
View a summary of the import options selected in the wizard.
