Before you begin: Make sure the workflow is valid
Before you start the validation and deployment process, validate the workflow to make sure that it is valid and that all of the study objects that it references still exist in the study.
If you receive an error during validation about an invalid workflow, perform these steps:
- At the bottom of the Project Explorer, click the Visit Schedule (
) button. - Select a study design, study element, or study event.
- Select the Workflow Diagram tab.
- Right-click the workspace, and select Refresh Workflow.
- Central Designer corrects the issues with the workflow. For example, if a workflow arrow is not pointing to anything, it is removed. You receive a message that tells you about any visible changes that have been made.
- If no issues are detected, Central Designer does not change the workflow.
