Create an incremental deployment package
You can create an incremental deployment package for a previously created deployment package when changes have been made to the study. The incremental deployment package contains everything needed to deploy a complete study, plus additions and changes to the study reflected in Alternate forms in InForm. Alternate forms are not created for repeating forms, or forms with a dynamic grid.
- At the bottom of the Project Explorer, click the Study Information (
) button.
- Right-click a study, and select Create Deployment Package.
- To start the Create Deployment Package Wizard, click Next.
- On the Select a Deployment Package Type page, select Incremental package and click Next.
- From the drop-down list, select the previously created deployment package for which this is an incremental package and click Next.
- From the drop-down list, select the validation baseline to use and click Next.
The date and time of the baseline must be later than the validation baseline used to create the deployment package selected on the previous page.
- Enter a name for the deployment package and an optional description.
- To use the default email dropbox, select Use default. Otherwise, enter an email address for the dropbox.
- To apply the newly deployed study version to all sites, select Yes.
- Click Next.
- Review the options and click Finish.
