Change the data value associated with a data series
When you add an integer or float item with a selected unit to a data series, you choose if you want to map the normalized value, entered value, or normalized units to the data series. You can change the data value that is mapped at any time.
- At the bottom of the Project Explorer, click the Data Mappings (
) button.
- In the Project Explorer, select a data series.
- In the grid, right-click an integer or float item, and select Modify data point value collected.
- In the Item has Units window, select the value to associate with the data series, and click OK.
